ianakapilotlight 21
Thanks for taking the time to look at this one, its had me stumped for the last 48 hours.
I'll get down to it, I am building a web service in the cloud. And I am trying to get the Fibaro HC2 to talk to it using a lua scene.
The code below works fine returning the correct status code '204' but only when called using HTTP. If I switch it to using HTTPS then I get the error "Connection reset by peer".
I have tested the service with both HTTP and HTTPS using PostMan and Insomnia REST clients, and they indicate that the service works.
It seems to be due to SSL and wonder if the net.HTTPClient is somehow failing me.
Perhaps you can suggest what the problem is?
