Sjd101 0
Hi
Very new to this. Trying to set up a simple block scene where by as I approach my house the Conexis unlocks. I have tried to set it up using GPS. I have set my home location, "Then" ask the scene to unlock Conexis. However, when you then try to select the lock under devices its not showing up to select. Any ideas? The device is obviously set up in the HC 2 and can lock and unlock via the App. The lock shows up in devices as The slave. The Master says unconfigured but not really sure what needs configuring in this section. Sure this has something to do with it but some guidance would be appreciated. I have attached a couple of screenshots to help
