Sending UDP Commands Lua
I'm a starter in programming for my HC2.
I made a Virtual Device (KMTronice, UDP Relay) and wanne send this code:
local ip, port = "192.168.100.166", 12345
local message = "FF0100"
local socket = require "socket"
sock, msg = socket.udp()
if sock then
  sock:setpeername(ip, port) end         -- connect to destination
  sock:send(message)
  sock: close()
But I get this error:
[ERROR] 13:32:10: line 2: unexpected symbol near '%'
[ERROR] 13:40:35: line 9: '' expected near 'end'
What I'm doing worng @ this script ?
7 answers to this question
is this part ok?
i get  a error on require
[ERROR] 16:06:08: line 4: attempt to call global 'require' (a nil value)
Edited by fkruis
    I don't know exactly.
    I wanne send a UPD command!
    Where can I find some basis scirpts ?
    Did some research and maybe I have to edit some, username + password.
    TCP I find a working script but not for UDP.
    not sure about model of the KMTronic you using, but feel free to try my VD
    You will have to create two global variables, relayone and relaytwo
    Edit: i use http and hidden Relais status, not UDP
    now regarding your code:
    if sock then
      sock:send(message)
      sock: close()
    you have unexpected 'end' in this line
    then you are using 'require', which ich not working on HC2 (it is not allowed to use it), so that code will not work.
    If you really need UDP, you can try following (i do send here udp data to KNX bone)
    Edited by tinman
    Thanks for your information.
     is not going to work because I have another version.
    So here I found some more information about he product:
    I tried also using Packet Sender, and works perfect. Without any username or password.
    So on the next Line:
    FF0000 - Status Read command
    FF0100 - Relay 1 OFF command
    FF0101 - Relay 1 ON command
    FF0200 - Relay 2 OFF command
    FF0201 - Relay 2 ON command
    FF0300 - Relay 3 OFF command
    FF0301 - Relay 3 ON command
    FF0400 - Relay 4 OFF command
    FF0401 - Relay 4 ON command
    FF0500 - Relay 5 OFF command
    FF0501 - Relay 5 ON command
    FF0600 - Relay 6 OFF command
    FF0601 - Relay 6 ON command
    FF0700 - Relay 7 OFF command
    FF0701 - Relay 7 ON command
    FF0800 - Relay 8 OFF command
    FF0801 - Relay 8 ON command
    FFE000 - All relays OFF command
    FFE0FF - All relays ON command
    I'm correct ?  for every buttion ? Or like a Toggle buttion if that's possible ?
    And about this line:
    -- if you need to do broadcast
    -- for example to do WOL
    -- socket:setBroadcast(true)
    socket:setReadTimeout(1000)
    Do I broadcast ? Because is sending some message ?
    Hello, Can somebody please post an UDP LUA SCRIPT FOR Sending specific KNX commands? using commands for switch on/off, dimm to group adreses in knx? Thank you
    • -1
    ok
    in principle you can do read the status in main loop, to show in labels and control them on/off with buttons, where each button have then set of values to send to relais
    local data = string.char(0xff, 0x01, 0x01) -- that should be Relay 1 ON command
    no you don't need these lines, you do send to specific IP (of the Relais), and not to all devices in the network
