How to delay Sprinkler based on Netatmo
Hi All,
I have seen many suggestions on that, but none of them works for complete programming ignorant.
Can anybody help with step by step instruction on how to stop sprinklers depending on either weather forecast, or better based on Netatmo rain gauge reading.
Any help appreciated, I’m so annoyed that my old Gardena was doing better job than Fibaro.
5 answers to this question
Hi, Im using VD with button that will set delay to defined time. Its being triggered by weather or manually. In your case, I believe it can be triggered by Netatmo (I dont have it to give it a try).
Edited by Igy
    Hi Igy, thanks but I use HCL and I could not use LUA. Is there a way to translate such code into string used by VD in HCL?
    Edited by PawRew
    I think that there is no way :-(
    @Igy Hey, I am also a noob if we are talking about lua code, but how can I set the virtual device to be triggered by netatmo rain gauge? Thank you very much!
    Edit: Also I want to apply it to a lua scene so I don't have to press buttons. The idea is to get the values from rain gauge and then from those values change the delay to the respective number of hours. For example, if it rains more than 100 ml the delay is set to 24 hours and if it rains more than 500ml the delay is set to 48 hours.
    Edited by Stiven
    Altough a few years old, this is still very nice code. Thanks a lot!
    I am not a programmer but was able to use the code for creating a new VD where I can manually delay rain for garden sprinklers.
    /monthly_2020_05/image.png.7a5178167b1b94cc1270290b4bbd221b.png" />
    I faced one problem: when I chose a delay, it kept setting that delay infinite. So I created 2 global variables, RainDelaySet and RainDelayHour. After each button I set raindelayset to 1 and RainDelayHour to the chosen hours.
    Now, when you press a button, it knows that you want to set to that value and when you do nothing, it counts back to no delay.
    I just installed Sankotronic Weather State and Forecast (man what an effort did he put in, respect! Well documented, good manual, outrageous). It works almost but now looking to integrate both, so I don't have to bother to set de delays myself.
    Example 24hr button:
    fibaro:setGlobal("RainDelaySet", "1")
    fibaro:setGlobal("RainDelayHour","24")
    Code for the +1 button:
    local RainDelayPlus = (tonumber(fibaro:getGlobalValue("RainDelayHour")) + 1)
    fibaro:setGlobal("RainDelayHour",RainDelayPlus)
    Code for the -1 button:
    local RainDelayMin = (tonumber(fibaro:getGlobalValue("RainDelayHour")) - 1)
    fibaro:setGlobal("RainDelayHour",RainDelayMin)
    Main loop code:
    HC2 = Net.FHttp("127.0.0.1", 11111);
    -- Get RainDelay from GlobalVar and Sprinklers Panel
    if tonumber(fibaro:getGlobalValue("RainDelaySet")) == 1
      then
        fibaro:debug("RainDelay ingesteld vanuit variabele en RainDelaySet 1 naar 0")
        RainDelayGlobalVar = tonumber(fibaro:getGlobalValue("RainDelayHour"))
          fibaro:setGlobal("RainDelaySet", "0")
        RainDelay = tonumber(fibaro:getGlobalValue("RainDelayHour"))
        response, status, errorCode = HC2:PUT("/api/panels/drenchers", '{ "rainDelay": '..RainDelay..'}')
          if tonumber(errorCode) == 0 then
             fibaro:debug("Connection successful.");
          else
           fibaro:debug("Connection failed!!!");
      else
        fibaro:debug("RainDelaySet 0 blijft 0")
    -- get data table from the Sprinklers Panel
    response, status, errorCode = HC2:GET("/api/panels/drenchers")
    jsonTable = json.decode(response)
    delay=jsonTable.rainDelay/3600
       function round(delay, idp)
         local mult = 10^2 -- number of decimal places
         return math.floor(delay * mult + 0.5) / mult
    fibaro:call(632, "setProperty", "ui.Delay.value", round(delay).." uren")  --display of actual delay on VD label
    fibaro:call(632, "setProperty", "ui.RainDelayVar.value", round(fibaro:getGlobalValue("RainDelayHour")))
    Don't know if it is well-coded (don't think so) but it works like a charm for me. As told, working on the automation from Sankotronics weatherforecasts.
    Maybe someone can use it.
    Thanks again @Igy
