tinman 1,071
One can for sure use global variable to store information, but i don't like them, as they will get overwritten (NaN) when the set value is not numeric and one or more variables with get changed via UI.
But there is something else what can be used, every device have property "userDescription", which can be used by user to store what so ever information about that device.
Everybody have at least device 1 (the HC2 itself), and the data can be stored there. Sure, one can use any other device to store information. Finally this is device property, so one can trigger on changes as well.
Example set property:
Example read/trigger property:
userDescription can be used as well as filter, e.g. to search for all devices where we set something (e.g. "spare device")
I haven't found yet size restriction, so let's go find it
, but remember, size matters (as data will be displayed in UI, the HCx is reading it each time and displaying - good for fast edit/patch, bad for UI speed, so hidden devices as e.g. HCx itself are better to store data).
Edited by tinman5 answers to this question
