innr RGBW bulb via HC2 HUE plugin - no module created
I am struggling to get a module and an ID# for the innr bulb.
The setup is:
HUE Base Station with 5 Phillips original bulbs, and now + 1 innr.
HUE Base Station is connected via Plugin to Fibaro HC2 and for every Phillips bulb there was an own module created where I could find the ID which I am using in LUA scripts.
The Innr Bulb is available in the Phillips App and everything works with it as expected.
In addition the innr bulb is also recognised/counted in the module (HUE) which covers all bulbs (6) - and if I switch all on/off the innr is doing the same as all the other original bulbs.
I also tried to find the ID# with HC2 Toolkit - no success.
Any ideas please?
Thanks in advance
