TurboWannaBe 5
I need help with a Differential temperature scene, where I will be able to set the delta temperature setpoint.
Got a swimming pool with solar panels, and what I want to do, is when solar panel gets, let's say 5 degree warmer than the pool water, i want to activate a Fibaro relay to turn on a pump/valve.
And when the solar panel reaches same temperature as the pool water or maybe 2 degrees above i want to turn it off.
T1 is connected to a UBS (solar panel)
T2 is connected to a UBS (water temp.)
V1 (Valve) connected to a FGS-223
Any help appreciated:)
