Scorpiozz 1
I recently installed a fibaro system controlling the lights in my house, all the relays are working fine except 3 channels on 3 different relays that are stuck on “on” and the lights are always on, can’t be operated from the manual switch either, the relays are carrying a light load of around 4 LED lamps, i tried switching the channels and the problem is still there, when i test the live load on the Q2 terminal it has power even though the switch is closed, unlike when i test “Q1” which has no power when the switch is closed. And when i install the lamp wires to the switch without the relay, everything works perfectly.
7 answers to this question
