Presence detection with UniFi: error accessing HTTPS controller site
I'm working on a scene for presence detection by reading the active Wi-Fi devices log from my UniFi Controller and put the state into a Virtual Device button.
To access the web API I have to login with a JSON post before I get the data. The UniFi website has a self signed certificate and I access it with an IP address.
I made the following code:
When I run it the following error occurs:
Quote
[DEBUG] 17:14:01: Error getting data (GetUserData): wrong version number
After some research I think it is a TLS version issue. The LUA HTTP library maybe tries to open the secure HTTPS channel with an incorrect version, or the self signed certificate is not accepted.
As I cannot get more logging than this on the HC2 I'm asking if some other developer on the forum had encountered this problem and has a fix for it?
17 answers to this question
    You are right 10der. It's insecure and I'm not going to edit my TLS settings on the UniFi controller.
    I installed an Node-Red/MQTT server and now I'm playing with it.
    node-red
    You flip the Virtual Device switch with Node-RED? and the Fibaro HTTP API?
    I don't get the Node-RED/Fibaro thing yet, I seems a hack with scenes to get it working.
    try following
    7 hours ago, tinman said:
    try following
    TLS23 issue here... FIBARO use tlsv1
    it's not issue, is something which can be fixed, all one need is to change system.properties from Unifi controller to:
    and HC2 can get the data
    /monthly_2018_07/image.png.1972490fffa8d33f913a784bb3df0a31.png" alt="image.png.1972490fffa8d33f913a784bb3df0a31.png" />
    so no reason to cry^^
    he-he... ok, will install windows 3.11.
    thank you!
    no worries, you have to create user with read-only access to stats, nothing more. That user is being used by HC2, with TLS1. To access from outside your home, you can use cloud access or reverse proxy, with websocket ssl/tls1.2
    However, when you already have raspi, you can run controller on it, and allow access only to specific hosts - or run even better let node-red and controller on same raspi.
    HC2 could support TLS1.2, websockettls (form plugin level only) has been already added, so let's hope for more.
    One can of course take the frak off way (oh how fitting to my 1000th posting):
    Edited by tinman
    8 hours ago, tinman said:
    frak off way
    You seem to be running a special firmware version - am I right?
    You've made my day!
    Edited by petergebruers
    Your Honor @petergebruers
    it's MS VSCode + see attachments
    Ok, thanks, I can run that locally but not on the HC2 4.054 because Fibaro sets "require" to nil... I saw you other post but I did not (yet) implement it because I use ZeroBrane Studio + link to HC2 (+ offline simulator) similar to yours. I see how that ssl.https fits in. Cheers!
    Edit: I'll install the "Microsoft Visual Code" on my Mac, just for fun, and try your integration ;-) - I know it is a very popular editor. But so is "vim" :-D
    with some other funny hidden API calls, one can assign e.g. the RSSI from any wifi device to virtual temperature sensors,
    and show them (well, unfortunately one room per wifi device) in UI (-dBm values)
    For sure not perfect implementation of VD into initialstate plugin (as one can't read labels directly), but at least something.
    6 hours ago, tinman said:
    Fibaro have added initialstate plugin,
    Hi @tinman,
    is this plugin documented somewhere, or is it the same a with all HC2 documentation?
    you made my day !
    Hmmm the same old story!
    • Thanks 2
    Hi @tinman,
    thank you very much for the elaborated how to. Great job!
