Change Label Virtual Device through API
I would like to ask wheter I can change a label of virtual device through an API?
Richard
14 answers to this question
Guest spazpeker
By using a global variable for the label Yes
    Thank you for your answer.
    This is indeed what I figured out. But is it possible to directly change it without use of global variable?
    Thanks again!
    or simple
    if I add a second label under eacheother and would like to change the second label, what do I need to change in the code?
    jsonTable.properties.rows[1].elements[1].caption="Checkin"; -- WHAT SHOULD I CHANGE HERE ??
    see photo below: The label named "test" I would like to change to "Checkout" ??
    /monthly_2018_08/checkin.PNG.de98f9ec300f03f19551d99490ffe44e.PNG" />
    Edited by samuel
    counting... 1, 2, 3....
    btw,.
    and look to json response
    rows and elements...
    i tried this:
    element 2
    or
    with row 2 and element 2
    but that gives me an error on this line
    in the api it said: row 1 > in lua = 2
    same with elements 0 > in lua = 1
    the above is for the second label from the above picture with label "test" becomes "Checkout"
    Hi have tried the the code. The json table update for the required element. I can change it. No problems there.
    However the virtual devise label is not "refreshing". Only when I reload the page I can see the change.
    Any idea ?
    Thats the same here
    FIBARO said about FAD
    @10der -  Thanks for reply, not sure what you mean "FAD". Could please outline ?  thank you
    ok. Thank you. My understanding is that you indicated the fact that the label is not refreshing was designed as such by Fibaro. Thus in order to display, one must find another way to refresh the VD.
    this designed by FIBARO.  I am not a FIBARo developer. ask FIBARO directly via ticket to support :)
