[email protected] 0
Hi all,
I have a problem and I hope someone can assist me.
I have two different scenes setup on two individual Fibaro Dimmer Relays. Both have been setup for the double click function and both work individually. One scene is is to turn all the lights off and the other to turn all the lights on...
In the lua script I test the condition of the "sceneActivation" property to check if the ID=14 (which is double click) on both buttons
Problem is that these scenes now cycle as the ID never reverts back from the 14. So essentially the lights turn off and then immediately get tested on the other scene (cause that button is still on ID=14) and the lights turn on again. Rinse repeat on the turn off cycle. Work around is to single click the button again to set the ID=16, but this is a pain.
So is it possible to set the "sceneActivation" property back to 16 in the Lua script?
Thanks in advance
Edited by [email protected]0 answers to this question
