drpillai 0
Hi all , I have 2 toggle switches controlling 2 lights. The wall switches work as they should ie.( Switch 1 turns Light-1 on and off / Switch 2 turns Light-2 on and off).
On my vera app , switch 1 works as it should but switch 2 is also switching Light-1 and doing nothing to Light-2. Everything seems to be wired correctly so not sure what the problem is. Parameter setting?
