"End of file" when trying to parse api.dryg.net through HTTPS
I have been using api.dryg.net to get day info and it has been working great until a couple of days ago.
I get Error 301, which i assume is due to webpage is not HTTP anymore, instead only HTTPS is supported.
Before i used a VD and used Net.FHttp :
local httpSession = Net.FHttp(ip, port);
local date = os.date("%Y/%m/%d");
response, status, errorCode = httpSession:GET("/dagar/v2.1/"..date)
If i have understood it correctly, i need to use a http:request instead and this can only be done from a scene?
When i do the following from a scene i get this:
local httpSession = net.HTTPClient();
httpSession:request("https://api.dryg.net/dagar/v2.1/" ..date, {
      options = {method = 'GET', timeout = 5000 },
          success = function(status)
          print(status.status)
          if status.status ~= 200 and status.status ~= 201 then print("failed"); end
          print(status.data);
          local results = json.decode(status.data)
          for k,v in pairs(results) do print(k, v) end
        end,
        error = function(err)
          print('[ERROR] ' .. err)
Response is :
[ERROR]End of file
Any idea what im doing wrong?
14 answers to this question
some notices/tips
about https
1) be careful with declare headers
for example (bad using Content-Length)
2) in some situation Fibaro can't get right http status response if status response != 200 (confirmed with long emailing with Fibaro support|)
3) https is not working in VD
4) https protocol is not properly implemented (confirmed with long emailing with Fibaro support|)
5) Fibaro use tlsv1 and you can't change this behavior.
protocol="tlsv1_2",
doesn't work
6) use checkCertificate = false option if you have self-signed certs
7) use a JS console/network monitor in your browser for clear understand what browser send to server... (use private windows mode)
    Thanks @10der !
    I will try out some of your tips and see if it works better.
    BR
    btw, opps. you can't.
    alas!
    Ahh.. Then i know the reason.
    Thanks again!
    BR
    Strange.. I copied your code to see that i get the same response but i still get "End of file":
    /monthly_2018_08/Scene.JPG.fd89bc6a80495e612f532d8d694e99e9.JPG" alt="Scene.JPG.fd89bc6a80495e612f532d8d694e99e9.JPG" />
    yay!
    look like FIBARO return rand() :)
    crazy!
    Ok. Thats interesting ;)
    I think FIBARO sometimes forgot to make disposing of processes... or something of the sort...
    Edited by 10der
    Any progress on this?
    I'm facing the same issue with calls to api.dryg.net. It stopped working from my Fibaro scene after July 29th without any changes being made to the scene code.
    /Jan
    I too faced this problem and raised a ticket with the support team the reply came back on 20th August
    "HTTPS is not supported"
    Is that still the case with latest firmware version?
    idk. I've stopped believing in FIBARO miracles. :)
    You can actually overcome this with
    As shown here
    Enjoy
    @ianakapilotlight, thank's for the answer. It looked promising, but I can't see that it makes any difference.
    My code:
    Can you get this URL to work from a Fibaro scene:
    I'm running HC2 4.510.
    /J.
    1
    no you can't
    [DEBUG] 21:56:31: 2019-02-06 21:56:31.103899 [ error] Handshake error: wrong version number
    [DEBUG] 21:56:31: 2019-02-06 21:56:31.104594 [ error] Handshake error: sslv3 alert handshake failure
    HC2 performs SSLv3 (AFAIR died at 2014y) requests but your server rejected it cuz asking not supported by HC2 protocol (TLS)
