Old cooling panel - needs rebuilding like heating panel
On the occasion of a stable update. do you plan to standardize the air conditioning panel (old) with the heating panel (new one)?
" to "
Temat został przeniesiony z "
" do "
I will submit it as an improvement suggestion :)
As I did not recall any plans to do so.
    It's not necessary @T.Konopka, but it would be logical to make the heating and cooling functions coherent
    it would be great if you do so I now use the heating panel and several scenes to run my cooling system.
    Because when you use the cooling panel you can't set the themprature in the app on the phone or tablet.
    only in the cooling panel so via webinterface.
    I use a rule to copy the roomsetpoint of each room from the heating panel to a global value.
    And then a scene to check the room temperature to the setpoint of each room.
    If the global value summer/winter is set for the summer, then the cooling will go on if the room temperature is higher than the setpoint.
    When it is set to winter the heating is activated if the room temperature is lower than the setpoint
    AMDIN'S NOTE:
    Edited by T.Konopka
    https://forum.fibaro.com/topic/30009-how-to-properly-attach-images-and-clips-to-your-posts/
