Missing LAN settings after recovery
Just bought a second hand HCL unit and got it today.
At first I could not connect to it via my home network - after a while I managed to reach the recovery console (through direct PC and IP 192.168.81.1)and did a full recovery on it.
Now that I want to change network settings to DHCP from the config menu all choices are gone.. blank..  Tried to recover 3 times now with same result.
Any hints or tips on how to fix this? Is it possible to get hold of an older firmware and recover from file perhaps.
The device is in 4.504 Beta..
Would appreciate any help on this.
Picture..
16 answers to this question
Got the exact same problem. I've upgraded to the latest version (4.510) and the HC2 is stuck on a static IP setup (192.168.81.1).
I can connect to the HC2, but get an empty 'network settings' menu so I can't change it back to DHCP.
The network file on the recovery USB stick is saying DHCP, but no reboot or recovery is able to get it into DHCP mode.
Any idea's ?
Since 1.8.2018, my remote access does not work. In the Wi-Fi network, I connect to HCL on both the mobile and the PC, outside the wi-fi network, which is also HCL, is not a remote connection. I did not change anything, did not set anything in either the router or HCL, nothing at all. It just stopped doing nothing. What with this? Where is the problem? Everybody puts their hands away and I do not enjoy it, the whole system is nothing! HELP!!!
Any idea's ?
Geert, I experience exact the same issue, no options to select in dropdown menu within Lan settings. I can't make a backup because at the it says that there is an error encrypting the backup file.
and I can't select an older backup as they became incompatible.
So I am desperate at this moment. I just opened a topic about this.
Rob (Netherlands)
Edited by Robvw_ehv
Picture..
Thank you for the tip to use default address 192.168.81.1.
Connected and after changing language from English to Dutch made the LAN settings available to me. I'm using the 4.510 firmware.
Kind regards, Paul
    Kind regards, Paul
    Happy that the information turned out useful to you.
    I got at total rapid crashcourse in HCL setup the day I got my first HCL that had been restored for too long and thus entered into "fixed IP mode".
    I got the HCL to work well but realised soon that I needed a HC2 some Im already on that now.
    Picture..
    Kind regards, Paul
    Just tried, but changing language for me didn't bring back the LAN settings. Any order tips from anyone ?
    Cheers
    Geert
    Just simply do an ordinary reboot by turning it off with the button. Wait. Then on again. No pressing buttons while start and so on..
    Guest chaicka
    Make sure to clear browser cache after changing language. Home Center kinda always have this caching issue since many many versions ago hence we make it a habit to clear browser cache.
    Clearing the cache didn't make any difference for me
    Reboot by turning off doesn't work
    Hi! Has anyone solved this problem?
    please find the solution give by Fibaro support for resolve problem of DHCP no posible to select
    It looks like your gateway lost LAN setting and you need to manually restore them via API.
    1) Please log in to the system.
    2) Please go to api using below command:
    Home Center IP address/docs (i.e. 192.168.81.1/docs
    2) From the list choose Settings and find option:
    PUT/settings/network
    3) Put below body:
    “dhcp”: false,
    “ip”: “192.168.81.1”,
    “mask”: “255.255.255.0”,
    “gateway”: “192.168.81.1”,
    “dns”: “192.168.81.1”,
    “remoteAccess”: true,
    “remoteAccessSupport”: 0
    Copy above settings into body and send them to your gateway. After you send this, please wait few seconds for system to respond.
    4) Now go to the interface, refresh it and check are your LAN settings visible in the system.
    5) If everything is OK, now you can set DHCP connection type and save it. After that connect your HCL to your router- now router should find your HCl and gives it new IP address.
    You can also set some other static IP (according to reservation on you router).
    6) After you connect your HCL with the router, please set correct data on your gateway. Go to Configuration  Location  Set Date and Time, choose Manually settings and set correct data and save it (system should reboot automatically).
    if not ok , you can try with in step 3
      "dhcp": true,
      "ip": "",
      "mask": "",
      "gateway": "",
      "dns": "",
      "remoteAccess": true,
      "remoteAccessSupport": 0
    daniel
    Daniel, many thanks, this worked !
    3) Put below body:
    “dhcp”: false,
      "dhcp": true,
      "ip": "",
      "mask": "",
      "gateway": "",
      "dns": "",
    daniel
    i tried it but somehow it didn't work at first...it said something was wrong. restarted everything and then it worked! Thanks. Was looking for a solution forever.
    In the End it's just not understandable how something like this can even happen. And worse, support was no support to me. At least in Germany...well hopefully the F... up is over.
    Hey guys
    I have tried the solution above but i get the following error.
    Response Body
    Response Code
    anybody can help me with that, my server is been down for couple of days since the last firmware update?
    I have exactly the same issue. Any news on that topic?
    this HTTP PUT doesn't seem to work for Home Center 2 version 4.560. It just returns 500 Internal server error. Any ideas?
