hello
what is this download ??
/monthly_2018_08/imo.PNG.cae50668b90a994530bdb3cf24467b81.PNG" alt="imo.PNG.cae50668b90a994530bdb3cf24467b81.PNG" />
actually wrong file extension, it is zip file which contains the same text as docx + picture.
Much better is this presentation ->
    merci
    thank you
    ...is really integrated with Smart Home Bot in new version  4.510 for HC2 (where is Help DOC )?
    For me this function and IFTTT will be the best !
    Edited by Jacek Stark
    Everything is in Fibaro knowledge base:
    Commands:
    How to Connect/disconnect:
    FAQ:
    OT:
    For CZ/SK users, that have problem with EN lang, i will leave here link for CZ translate:
    " to "
    Temat został przeniesiony z "
    " do "
    Commands:
    FAQ:
    Thank you very much.
    @jakub.jezek
    Need i to have acount on m.Facebook.com use Smart Home Bot by Messanger app ?
    I can`t login on my Messanger comunicator.  I have not acount on Facebook, only on Messanger.
    Hi @Jacek Stark, you should need only Messenger.com account and Fibaro ID account.
    @jakub.jezek
    After correct login I get a message from Fibaro bot:
    /monthly_2018_08/image.png.1adabbcbbd9790ebc9ecd5d0b747166d.png" alt="image.png.1adabbcbbd9790ebc9ecd5d0b747166d.png" />
    @Jacek Stark, interesting. So to be clear,  Fibaro Smart Bot redirects you to Facebook?
    @jakub.jezek
    When i login to Messanger app in English i loged but i get now new message:
    /monthly_2018_08/image.png.cdba99cd9469b33223f2378a17f77da4.png" alt="image.png.cdba99cd9469b33223f2378a17f77da4.png" />
    @Jacek Stark,  what happens if you try some commands. Like Turn on all lights? Seems like it does not understand command Welcome.
    @jakub.jezek
    ...all times the same. "Sorry, something went wrong......"
    In app ID Fibaro i don`t need do enything ?
    Hmmm. Interesting. Can you try some commands in spoiler below? If it does not work, please contact Fibaro support, because i ran of the ideas.
    In my case it works smoothly.
    @jakub.jezek I will try something else later. Thank you for your time.
    Now is OK. FSHB answers right. Once more thank you for your time.
