Dear community,
is it right, that it is not possible to select a length for switching on the watering system in the garden via the app? Only via the web-based platform? For the heating system it is possible, it must be a relatively easy to add.
Dear people from Fibaro? Is this planned?
What might happen is that one is away on holiday and switching on the watering system. If suddenly there is no WiFi and no internet on the phone the watering doesn't stop! (I know, you can set a maximal time, I did it now...). This happened to me... :-(
Thanks in advance.
Schabernacki
Guest dobsovicj
yes, you are right, it is not possible to do it from the mobile application, you can start or stop watering only.
But you can create some VD and/or scene(s) to control watering system...
Or wait for FIBARO :-).
For such a critical "system" i used the max ON time directly on the device as a security option (e.g. 15 minutes). Now I'm only nervous, what if the relay got stuck (welded) for some reason....
