I am trying to every 15min check if my motion sensor has NOT been breached during the last 60s. If so turn of the light. The block scene that I created seem to "every 15min" check "if Motion is not equal Breached during the next 60s". I want it to check if it has not been breached during the last 15min. Can this be expressed?
/monthly_2018_08/image.png.49ed233fdb5dd1b2ff7606372c18b2a3.png" alt="image.png.49ed233fdb5dd1b2ff7606372c18b2a3.png" />
I have a similar scene which I can share but it works differently from yours.
My scene triggers when motion is detected and switches the kitchen lights on and then enters a wait.  During this wait, it checks for further triggers and if by the end of the wait (or loop) and no further triggers then turns the lights out.
Let me know if this is what you'd want, it is a LUA script but that should be ok as I see you have the HC2 like me.
    Hi ianakapilotlight,
    yes, please share the script and thanks a lot for the offer.
    Have a nice day
    /Christian
    You will need to customise this according to your controller and I've added comments to the code which also highlights the values you need to change.  Hope that helps
