vooodooo 0
ich quite not sure if my cabling between the two item is correct. before the fibaro roller shutter the manual control worked like this:
press switch a = roller shutter down; switch b is blocked
press switch a ("back") = roller shutter stops movement; switch b is not longer blocked
press switch b = roller shutter up; switch a is blocked
press switch b ("back") = roller shutter stops movement; switch a is not longer blocked
now the fibaro roller shutter takes over the controls - with this result:
all back switching is ignored - to really stop the movement i have to press on switch again. This is not descriped in the manual; so im note sure if its an error or the correct behavior of the shutter in connection with the Fibaro Roller Shutter.
Can anyone help?
Thanks in advantage
Edited by vooodooo2 answers to this question
