Hi!
I've got a electric gate at home, which can be openend with a remote or a press on a momentary switch which is inside the house. The momentary switch is directly connected to the "Tousek gate control unit" :
It sends a pulse to the control unit and then the gate opens. (see pic for the momentary switch on the low right.
Now I really like to open it via my SmartHome app, trough a "Fibaro Single Switch". https://www.fibaro.com/en/products/switches/
My question is: is it possible to place the Figaro switch inside the momentary switch? (easiest option) or maybe even in the gate control unit?
I sadly have no experience at all with electrical engineering..
I hope somebody might have the answer! :)
you can place the Fibaro switch inside the momentary switch or in the gate control unit. it's your choice....
But, please be careful... you need to use dry contact switch. Fibaro first edition switch (FGS-211/2)
yes, that's right @CAG014.
