Hello Everyone,
I 've started a project on github for Fibaro and several integrations like Grafana and Microsoft Azure.
Seems very nice and i am currently develop the Machine Learning Algorithms for Home Automation Anomaly Detection.
Everything is server-less and soon notification engine and device recognition will be included.  For the moment you can see real time data from Power BI.
68747470733a2f2f7661797563672e616d2e6669
Next step is the Cortana Voice Commands integration.. :-)
Also within the same Solution you can find the integration with Grafana and InfluxDB.
You can find the solution here: https://github.com/evkapsal/Fibaro-Home-Automation
Thank you...
  • Thanks 3
Great! Thank you! Keep on developing ;-)
That is soooo cool ! (I wish I had the time to domstuff like this)
question, wouldnt it be possible to talk to the HC2 directly from powerBI (via the HC2 rest api?)
    Hello Guys,
    Thank you for your support.. :-)
    I am currently finished my new version for Azure IT Hub, and Azure ML Algorithm (Trained Model) for Power/Energy Sensors.
    @Vinisz, i think that should work also for HC2, because as i read it uses the same Rest API.
    1.Create your Azure IOT Hub.
    2. Fulfill the Python Script with your credentials.
    3. Create an Azure Stream Analytics Job, input Azure IOT Hub and Output Power BI Api.
    4. Start the Script and Ready to Go! :-)
    i don;t think that you can have real time data without Azure IOT Hub and ASA to Power BI, only static dataset.
    I will have a very nice update this week. We have a vacation time here in Greece and i 've found some time for extra lines.. :-)
    Cheers,
    Edited by Vangelis
    Nice, Looking forward to the update....
    Good choise! HCL is a perfect target :)
    Yet, thanks for a good job!
    Read the descriptions of the categories:
    Quote
    Forum
    Do you have a suggestions about the Forum? Any comments about the Forum? This is the place!
    Your thread does not belong to the category.
    Also, get familiar with the guides on the Forum, like this one below:
