How to getValue from a label in a VD ?
How to get the vlaue from a label in a VD ?
I want to read the status from a label in a VD, how to do so?
if  fibaro:getValue(189, "ui.verandaspots.value") == 'ON' then
fibaro:debug("TEST")
Link to post
6 answers to this question
This is correct... please note you should use label's ID and not label value.
                                                    label ID
Link to post
How can I Debug the Value, by me stand all the time "Nil"?
 fibaro:debug(fibaro:getValue(488, "ui.Labe3.value"))
Edited by Jothebone
Link to post
@Jothebone
If you're interested
"universal" get:
function getPowerState(dev)
    if dev.powers ~= nil then
        for i, id in ipairs(dev.powers) do
            if fibaro:getType(id) == "virtual_device" then
                local statusLabel = dev.powers.status or "lblStatus"
                local state = fibaro:getValue(id, "ui." .. statusLabel .. ".value")
        		if tonumber(state) ~= nil then
          			return tonumber(state), os.time()
				else
                	if state == "ON" then
            			return 1, os.time()
            else
                local deviceState, deviceLastModification = fibaro:get(id, "value")
                if (tonumber(deviceState) > 0) then
                    return tonumber(deviceState), deviceLastModification
        return 0, 0
    else
        return 0, 0
"universal" set
function setPowerState(dev, value)
        local function hex2rgb(hex)
            local hex = hex:gsub("#", "")
            return tonumber("0x" .. hex:sub(1, 2)), tonumber("0x" .. hex:sub(3, 4)), tonumber("0x" .. hex:sub(5, 6))
            local lightType = GetDeviceType(id)
            if (lightType == "com.fibaro.multilevelSwitch") then
                if type(value) == "string" then
                    fibaro:call(id, value)
                else
                    fibaro:call(id, "setValue", value)
            elseif (lightType == "com.fibaro.RGBW") then
                    local r, g, b = hex2rgb(value)
                    fibaro:call(id, "setColor", r, g, b, 0)
                else
                    if value > 0 then
                        fibaro:call(id, "setBrightness", value);
                    else
                        fibaro:call(id, "turnOff")
            elseif lightType == "com.fibaro.binarySwitch" then
                if value > 0 then
                    fibaro:call(id, "turnOn")
                else
            elseif lightType == "virtual_device" then
                -- on = 1, off = 2
                local btnOn = dev.powers.on or "1"
                local btnOff = dev.powers.off or "2"
                local sliderName = dev.powers.slider or "2"
                if value > 0 then
                    if value ~= 99 then
                        fibaro:call(id, "setSlider", sliderName, value);
                    else
                        fibaro:call(id, "pressButton", btnOn)
                else
                    fibaro:call(id, "pressButton", btnOff)
            else
                if value > 0 then
                else
function idIsInList(id, list)
    for i = 1, #list do
        if (id == list[i]) then
            return true
    return false
local RGBWDeviceType = {"com.fibaro.RGBW", "com.fibaro.colorController", "com.fibaro.FGRGBW441M"}
local BinaryDeviceType = {"com.fibaro.binarySwitch", "com.fibaro.FGWP101", "turnOn"}
local DimmerDeviceType = {"com.fibaro.multilevelSwitch", "com.fibaro.FGD212"}
function GetDeviceType(itemId)
    local deviceType = fibaro:getType(itemId)
    if (idIsInList(deviceType, RGBWDeviceType)) then
        deviceType = "com.fibaro.RGBW"
    elseif (idIsInList(deviceType, BinaryDeviceType)) then
        deviceType = "com.fibaro.binarySwitch"
    elseif (idIsInList(deviceType, DimmerDeviceType)) then
        deviceType = "com.fibaro.multilevelSwitch"
    elseif (deviceType == " com.fibaro.philipsHue") then
        deviceType = "Philips.Hue"
    return deviceType
Link to post
bonjour
Comment récupéré la valeur d'une étiquette dans un VD?
ça ne fonctionne pas 🤥
How to recover the value of a label in a VD ?
it does not work
local comptid     = fibaro:getValue(484, "ui.label4.value")
fibaro:debug("MOYENPOMPE>>> " ..comptid)
merci de votre aide
Thank you for your help
Link to post
