Zipato Keypad - how to arm/disarm regardless of the keypad status
I don't think it is mentioned here in the forum - during the last weeks I found some guidance how get  the "Away" command once more if Zipato Keypad is already in "Away" state on HC2. Same for "Home" of course. Kudos to the unknown user who provided a blog post on this. Sorry mate, I cannot locate your original source anymore. However it seems there is a post about this in the Polish forum, I can't really tell because I don't speak Polish.
In essence there are three steps to achieve this:
1. Get the scene triggered by the Keypad's AccessControlEvent. The keypad ID in my case is 200.
2. Read the event data to get the status of the event
3. Act upon the value of operatingStatus
... where arm() and disarm() are the function you want to call on either event.
For reference here is the full scene in my setup. I'm using HomeTable, you get the idea.
Hope this is useful.
Cheers,
jayrock
  • 7 months later...
[DEBUG] 01:38:22: Triggered
[DEBUG] 01:38:22: 2019-03-15 01:38:22.435300 [ fatal] Unknown exception: /opt/fibaro/scenes/19.lua:37: attempt to index field 'event' (a nil value)
Seems like "operatingUser", "operatingMedium"", "operatingStatus" and "operatingKeyPad" are responding a nil value
KeyPad ID is correct and KeyPad is working fine with other scenes
Any advices?
Cheers
Andi
    Please print out trigger by adding adding a single line to the get event data part:
