this is my first day with fibaro and the programming of lua. the first 42 seconds is correct. but the 6 seconds is sometimes 3 seconds and then again 4 seconds. always different. what am I doing wrong
%% properties
%% events
%% globals
fibaro:call(78, "close")
fibaro:sleep ( 42000 )
fibaro:call(78, "stop")
fibaro:debug ( 'De rolluik is dicht ' );
fibaro:call(78, "open")
fibaro:sleep ( 6000 )
fibaro:debug ( 'De rolluik staat op 80% open' );
You're not doing anything wrong. Fibaro system is bad. You're lucky if not matching seconds is you're only problem :/
I'm wondering how you measure the seconds?
Please pay attention that fibaro commands executed without any confirmation when its actually done. I mean you can send command like
fibaro:call(78, "open") , but you can never know when its done. Depends on your system load and z-wave performance
