What happens if a Fibaro Dimmer 2 is by mistake connected with reversed polarity, means L and N are reversed?
I am thinking of installing a Dimmer 2 in the base of a lamp I want to control, according to the attached minimum scheme. However, I cannot ensure that the mains plug is always plugged in the right way (conductor to conductor and zero to zero).
What happens if the lamp with Dimmer 2 inside is plugged in the wrong way? Does the module have a reverse polarity protection circuit? Will it break, or even worse many risk of fire?
With AC, there is no polarity as with DC. Switching L and N would cause no problems.
youre picture shows no N, so if you reverse the powerplug the light will stay off
    Yes, that works. It's the minimal 2 wire connection, where the dimmers uses the consumer as N. Nevertheless using a third wire with N when available is better.
    Picture is taken from Fibaro Manual btw.
    Yes, thank you. Was confirmed by several electricians too, meanwhile. And indeed works fine.
    Edited by Wegerhoff
    Formattting
