sjamaBe 0
Hi, I observed recently a couple of times the following :
I have Sonos control linked into HC2 with a variable called x_sonos_object. When fresh installed everything works fine and I can control my Sonos from my HC2.
I have also some other variables in the variables panels and when I change one of those variables manually it then requires to save those by hitting the save button at the right, then the sonos variable is also changed and I can no longer control my sonos from my HC2. Simply hitting the save button in the variable panel also creates the same issues.
Anybody an idea how this can be avoided ?
5 answers to this question
