mobile pop-up notifications
I want to make a mobile pop-up notifications and followed the Knowledge Base
The pop-up shows on my phone, but I got two problems:
1. where can I find my Icons? I guess it's a location in the HC2 and not on my PC.
2. For the Button I add my scene number, but the scene is not triggered if I hit the button.
buttons = {
    { caption = 'Yes', sceneId = 128 }
Any help on this would be great.
Cheers
5 answers to this question
You can use the following function and set parameters for popup. Also you can change the icon or the type of notification.
Please define about icons. do you want to see the icons that are saved on your fibaro device? you can you the following re preview icons inside HC2
    Hi Korniza,
    thanks for the answer,
    I will try it.
    For the icons I like to use my Icons which are already in the HC2 devices section.
    Cheers
    Hi Korniza,
    thanks I found the Icons. :)
    But still for the scene it's not work.
    I tried you suggestion, but I think there is something missing, like in the original proposal.
    buttons = {
    Hei, did you manage to get this working? I'm looking at this option now.
    I wanted to do the same thing , put in my own icons , or access icons stored in my HC2.
    Searched all over the forum and net but can't find any info.
    I have the scene working with yes and no functions, yes turns on the lights - no turns off the lights
    Marcus
    Marcus
    Hi, I just got it running.
    The problem was quite stupid.
    One the iPhone and iPad I’m logged in as an user. That means you have also to give the rights for  the scene in the user settings.
    Once the user got the rights for the scene all works perfect.
    The sad thing is this is nowhere mentioned.
    Hope it helps.
