debug error lua:191: 'then' expected near ')'
I added a second sensor to my lua scene. and im now receiving this fatal exception. any pointers would be great!
[DEBUG] 15:50:30: [1;31m2018-08-21 15:50:30.843858 [ fatal] Unknown exception: /opt/fibaro/scenes/60.lua:191: 'then' expected near ')'
5 answers to this question
There is exactly the problem as the error message says. One opening bracket is missing or one closing is too much.
Remove the last closing bracket in line 189
    @Alex thanks! i didnt realize the extra on 189 was causing that. it fixed the issue.  now i have new one after starting the scene.. hopefully you might be able to find the error. it says i have an unexpected ')' on  203.  i combed through it looking for typos and couldnt find any...
    Add one opening bracket at beginning of line 200
    ( I am not sure if your or/and constructs are all right).
    error here
    (tonumber(fibaro:getValue(jT.entrance.motion2,'value')) > 0) ) and
    should be
    (tonumber(fibaro:getValue(jT.entrance.motion2,'value')) > 0) and
    @matt1981
    May I suggest to define jT as global variable of the code. In this case you do not need to define it again and again in every function.
    To do so, just remove local statement at  the beginning:
    jT = json.decode(fibaro:getGlobalValue("jTable"))
    instead of
    local  jT = json.decode(fibaro:getGlobalValue("jTable"))
    Now you can delete all local definitions of jT in all functions
