No internet - No HC2
Hi!
who can confirm:
- unplug RJ45 with provider internet from the router
- be sure what local net is OK
- be sure what app from iPad (for example) can be open
- be sure what you can be logging to UI (*)
- so, now if check on / off any switches - with no luck
- fibaro UI show old values un motion sensors
- totally HC2 look like dead.
UPD:
APP for Ipad after reload - not works
desktop UI show me empty.
8 answers to this question
I think you are in the dark side of the moon :)
I tested on tablet. everything is working
    leave HC2 without internet for 15 mins for example...
    Ok! See you in 15 mins
    No issues found.
    Lucky you!
    same here, no problems with 3 HC2s, so it will be your setup (or better said all the things you developed / connected via network to HC2)
    no!
    ok! trying to reboot.
    internet channel still is broken (ISP outage)
