Hello.
My first post - please bear with me!
I have a fireplace, which can be switch on and off with a couple of dry contacts. It's powered independently of the contacts.
See the image supplied.
I bought a Fibaro Single Switch - but I think that is going to supply power rather than just bridge the contacts. Have I bought the wrong thing? Or how should I connect this up?
I'd really appreciate any advice!
Thanks,
Antony
Please use any of this Philio PAN06, TKB TZ74 or Fibaro Double Switch (ver.1) with separate circuit from z-wave module.
    Thanks for the responses, but I'm still confused.
    1) I intend to use HomeKit, so no need for "Ok, Google".
    2) The fireplace I have already supports automation. All I need is the ability to bridge two contacts for "on" and unbridge them for off. The diagram I've provided shows what I need to do.
    My questions are:
    1) Can I do this with the Fibaro Single Switch? If so, how do I wire it?
    2) If I can't, what do I need instead, and how would I wire it?
    I hope this is clearer.
    The fireplace manufacturer said:
    Yes, all devices are endowed with a "dry contact plug  and connector" (potential-free contact). So you are able to connect with 2 wires any home automation system, remote button, Wifi or Bluetooth emitter, etc.
