API: Host not found (authoritative)
Hi!
the issue  is directly linked to a losing HC2 internet (not local.net)
hey FIBARO, would there any chance to resolve host name>
IMHO the problem was that the constructor for query has the address_configured flag set by default which won't return an address
if the loopback device is the only device with an address. By just settings flags to 0 or anything other than address_configured the problem is fixed.
please check your source code!
since the client cannot resolve the host (presumably because you cannot reach a resolver or DNS server because you're not connected to the network) then you're supposed to catch the exception and deal with it accordingly.
This looks like a Boost.Asio issue, which I think will only come up if you have a DNS server set up in your environment, but your network is down and thus the resolver cannot be reached.
PS:
Edited by 10der
not necessary, it might be something else as well, or both, or even more :\
I am getting this in scenes that are not making any API calls at all.  And the frequency is increasing day by day.
As an example in a motion_based scene, the trigger from a motion sensor runs the scene, which checks its status and I get this fault.  Its not every day in that scene.  But when it happens, it fails on multiple devices in a window of a few minutes.  And then it starts to work again.
