How to setValue to a Dimmer ????? (URGENT)
I need to set dimmer value to 50 real quick
/api/devices/40/action/setValue    .... <-- NO IDEA WHATS NEXT
/api/devices/40/action/turnOn  <--- this work fine , value become 99
4 answers to this question
Hello
 Where the 0 is the value of the dimmer and of course the device ID
    On 8/23/2018 at 1:05 PM, sonnyboy said:
    Hello
    i have tried this but its not working at all .
    0
    I can turn on and off the dimmer using Fibaro Documentation .
    http://192.168.1.999:80/api/devices/99/action/turnOn
    But nothing work with setValue at all :o
    Guest fat
    Have you checked the settings of the dimmer to ensure it has it detected as a dinmavale load?
    Are guy able to dim the light to the desired level with the app or web UI?
    Yes we can dim the light using the WEB UI
    I just found the solution : i need to add { "args : [ value ] } to the Body of network request directly
       is not work at all
