marbe 23
I use creating new global variables via virtual device and LUA. But now I need to create enum global variable, and it works not for me.
My tests:
1- I create enum GV with states 1,2,3
2-on response I get
response=HC2:GET("/api/globalVariables/test")
3-Now I need to create new GV with new name, but same response
There must be changed isEnum parameter to 1 (from true)
Now is new GV created, it is enum, but with no states, its only empty!
Same json works at docs well, but not at LUA code. This json at docs PUT /globalVariables/{globalVariableID} modified GV to enum with states:
Why LUA code doesn't create states as well as docs API? How is well syntax for parameter enumValues?
Thank you very much
Martin
7 answers to this question
