Arm delayed sensors not cancel arm delay after fibaro:call(deviceID, "setArmed", 0)
I use Fibaro HC2 as intruder home system.
I found, that if I during arming procedure with arm delayed sensors need to disarm system (I use fibaro:call(deviceID, "setArmed", 0) loop for all alarm sensors), all armed sensors are disarmed, but sensors with arm delay continue with arm delay and on the end are armed even if they was disarmed with command during arm delay period. At the moment disarming are the arm delayed sensors at disarmed status, but they must cancel arm delay too.
That very annoying, because if I need go back to home after arming and during arm delayed period, the sensors are not disarmed and after delay are they armed and it ended with alarm.
Thank you
    Or is there possible clear parameter "armTimeTimestamp" at device myself? Its parameter timestamp to end armDelay
    I cant find such action at API, but I don't know, what it mean : setInterval action.
    "actions": { "abortUpdate": 1, "forceArm": 0, "meetArmConditions": 0, "reconfigure": 0, "retryUpdate": 1, "setArmed": 1, "setInterval": 1, "startUpdate": 1, "updateFirmware": 1}
    Thank you
    " to "
    Temat został przeniesiony z "
    " do "
