How to left run only 1 instance of scene by multiple trigger at same time
I use scene for check arm status, alarm status, by triggering them more sensors.
Everytime then are started more instances at same time of the same scene. Then I need left run only one instance.
I tried more scenarios, with fibaro:countScenes(), timing by deviceId, but nothing is good solution.
Now I tried get running instances via API, but there are only these information's ["property","property"]. I was hoping that I will find information with deviceID, then will be possible to left run only instance with lowest deviceID.
Is there other posibility how to left run only one instance, if more instances are starting at same time, e.g. on arming?
Thank you very much
Hi @marbe, I know @jgab managed:
But I don't understand how :)
    Yes, that's great idea. Now I use two scenes one instead:
    - first with device triggers, it only set global variable, I set timestamp of last start
    - second in loop, with no trigger, it only check global variable for new timestamp, and after it start code
    with this solution runs my code uniquely.
    Thank you
