Light randomly on and off
My customer wants to create following scene. Unfortunately I do not handle LUA-coding so any help is really appreciated !
Customer has following devices: Home Center 2,  a lux sensor and wall plug.
Goal is: Creating a Scene that checks if lux is below value 50 and when lux is below that value then put light ON between 19:30 - 23:30 randomly.
So in another way to put it... if lux is below value 50 then put light ON if time is between 19:30 - 23:30 randomly everyday for 15-45 minutes which is random.
Example:
Monday: Time is 19:30 and lux value is <50. Put light on behind wall plug for 45 minutes. Then shut down the light (time 20:15). Put light again 20:45 and shut down it 21:00. Again ON at time 21:20 and so on until 23:30 put the light off completely for that day.
If lux is belov value <50 for example 19:45 then put light ON (Wall plug) like mentioned above (randomly and for random time).
Tuesday and rest of the week same thing...
Edited by janton
7 answers to this question
look like this
    Can you please tell how long the light will be lit per time or is there random time in the code ?
    Because I can not "read" the LUA-code ... can you explain how the code works :-D
    I could not get it working... the wall plug (local powerId) do not start at all between local rules times.
    Can I just copy the code or is there anything to add or change except following parts:
    I tried this morning (09:22-10:00) below code and wall plug did not turn ON ? Did I miss something ?
    %% properties
    449 value
    %% globals
    function between(timestr)
        local dayMap = {["1"] = 1, ["2"] = 2, ["3"] = 3, ["4"] = 4, ["5"] = 5, ["6"] = 6, ["7"] = 7}
        local smap = {
            ["Sunset"] = "sunsetHour",
            ["Sunrise"] = "sunriseHour",
            ["Evening"] = "sunsetHour",
            ["Morning"] = "sunriseHour"
        local function trim(s)
            return (string.gsub(s, "^%s*(.-)%s*$", "%1"))
        local function offset(s, o, p)
            if (not (o and p)) or o == "" then
                return s
            local h, m = s:match("(%d+):(%d+)")
            local t = 60 * h + m + (o == "+" and p or -tonumber(p))
            return string.format("%02d:%02d", math.floor(t / 60), t % 60)
        local function sec2hmStr(hms)
            local h, m, s = math.floor(hms / 3600), math.floor((hms % 3600) / 60), hms % 60
            return string.format("%02d:%02d", h, m)
        local function betw(interv)
            local dt, start, stop = os.date("*t"), interv:match("^([%S%a0-9%.%:]+) ?(.*)")
            stop = stop == "" and start or stop
            local d1, h1, m1 = start:match("^([%S%a%.]-)%.?(%d+):(%d+)$")
            local d2, h2, m2 = stop:match("^([%S%a]-)%.?(%d+):(%d+)$")
            d1 = d1 == "" and (dt.wday == 1 and 7 or dt.wday - 1) or dayMap[d1]
            d2 = d2 == "" and d1 or dayMap[d2]
            local d = dt.wday == 1 and 7 or dt.wday - 1
            if not (d >= d1 and d <= d2) then
                return false
            m1, m2, t = h1 * 60 + m1, h2 * 60 + m2, dt.hour * 60 + dt.min
            if (m1 <= m2) then
                return m1 <= t and t <= m2 -- 01:00-02:00
            else
                return m1 <= t or t <= m2 -- 23:00-21:00
        timestr =
            timestr:gsub(
            "$(%w+)([%+%-]?)(%d*)",
            function(s, o, p)
                return offset(smap and fibaro:getValue(1, smap) or fibaro:getGlobal(s), o, p)
        for _, interv in ipairs(split(timestr, ",")) do
            if betw(trim(string.gsub(interv, "%.%.", " "))) then
                return true
        return false
    local powerId = 729;
    local luxId = 449;
    local minLux = 50;
    -- rules sample
    -- Mo - Fr = 09:22..10:00 and 20:45..21:00
    -- Weeakend (Sa, Su) = 19:30-22:00
    -- also you may use mnemonics
    -- $Sunset..22:00
    -- $Sunset+15:00..22:00
    local rules = "1.09:22..5.10:00,1.20:45..5.21:00,6.19:30..7.22:00";
    while true do
        local status = fibaro:getValue(powerId, "value");
        local lux = fibaro:getValue(luxId, "value");
        if between(rules) then
            if lux < minLux then
                if tonumber(status) == 0 then
                    fibaro:call(powerId, "turnOn");
        else
            if tonumber(status) > 0 then
                fibaro:call(powerId, "turnOff");
        fibaro:sleep(1000 * 10);
    error code is:
    [DEBUG] 09:22:19: [1;31m2018-08-30 09:22:19.547975 [ fatal] Unknown exception: /opt/fibaro/scenes/601.lua:88: attempt to compare string with number
    Edited by janton
    sorry. I provided code like an idea.
    I never tested this code.
    if you can't develop as smb to help this. I can't.
    this should works.
    no support! as-is!
    thank you for understanding!
    Edited by 10der
    code updated
    thanks !
    Now the code works almost great. The problem is now that the light will lit exactly 5min. and pauses exactly for 5 minutes. Is there still something wrong with the random timings ?
    Ah! sorry! u rigth!
    prev. post have updated!
    pls do not spam me to PM
    Edited by 10der
    thank you very very much ! I am really appreciated for your help.
    Now the code works perfectly :D
    welcome!
