[Solved] VD http POST
I try to build a VD that is required to perform a POST request and read results. Is there any example? I like something simple to understand the mechanism of POST on VDs.
Help please!!!
 Edit: I just want a HTTP POST without authentication or send any content.
Edited by korniza
9 answers to this question
1 minute ago, korniza said:
any quick example please? :)
I am waiting for this, lazy-boy! :D
    @10der I try to use the following api call as a button on VD.
    I think if someone help, I will move forward to a dream....
    Quote
    POST requests need to set the header: content-type: application/json
    You can't.
    Fibaro VD doesn't support custom headers. ¯\_(ツ)_/¯
    1 minute ago, 10der said:
    You can't.
    Understand. can be done from scene?
    yes!
    YAHoooooooooooooooooo! I get results!!!
    I'm on track! I have a huge project for weekend!!!
    You've probably fixed this already, but if not here is where I have done this
    You can see here I am calling this method and passing in the headers I needed here
