[Questions] Working with Tables
Hello all,
I try to use a table inside a VD like the following
1st problem is how I can add ID_VD inside this table (instead of device1, device2). I miss syntax about this.
2nd is I try to split/read the names of devices (it suppose to have device IDs). An example will help.
My basic concept is to build a VD that will create a global table if it not exists. Also if Global Table exists, It will check if VD is registered. If not, will add it to existing table.
The reason is that if someone has more than one device, it will populate just one table.
4 answers to this question
Why do you json value? Why don’t you just use a nested table and then json the whole thing to store as global var?
this is a nice tutorial that may help:
Edited by 3JL
    @3JL thank you for answer. I will try but as I see it did not fit on my setup.
    6 minutes ago, 3JL said:
    I used the previous format according to following guide. I m on learning mode so I try hard :) . Any help is welcome!
