Guest Tango.Oscar.Mike
Guys, I am controlling our blinds also by temperature to help keep the upper floor a bit cooler during summer. To keep them down even the conditions (LUX) are met to usually have them open, I use another variable which defines "it is hot" and thus does not open the blinds during daylight. Also, the bedroom is controlled separately in the morning. Now the problem, every time the the variable "Temp_Front_22" is set to "off" - which is done by the scene which closes all blinds when it gets dark automatically, the blinds in the bedroom are opened! How can this happen? This scene below should actually only run at this specific time set? Why does it run at any time when the other conditions are met?
As you might know from my introduction, I am a HC2 noob, but I would understand that "at exact time" is a condition which is only met once per day for just one second or maximum one minute (since it does not specify seconds)! Please enlighten me. Many thanks in advance!
/monthly_2018_09/image.png.499ba53ebd6a23dffa24c52996a12df2.png" alt="image.png.499ba53ebd6a23dffa24c52996a12df2.png" />4 answers to this question
