Best motion sensor with longest battey ttime?
Any inputs on my topic from forum users?
  • 1 month later...
Have you tried to find something on google?
  • 4 weeks later...
Hello, are you looking for outdoor or indoor motion detectors ?
_______________________________________________________________________________________________
Edited by ekrem
isn't there a way to place them on a usb powerbank
Some motion sensors work with a usb powersupply. Could that be a solution? Else Fibaro sensors are relatively good to save energy. Some of my sensors are two years old with the same battery.
I hot them to and must replace them every 9 or 11 months
Hi, besides the 4 Fibaro sensors and 1 Aeon 5in1 sensor I have also this Chinese one (
). Honestly, I do have it for 1year and not a single issue with it so far. Battery seems to be still full, no false alarm (2 new Fibaro sensors), no stuck in breached position (2 out of my Fibaro sensors), no battery drains (Aeon). Not mentioning the price, its worth to try.
Hi @Igy ,
Just checked link to that Chinese PIR sensor that you provided and there is note that it is not available any more. Anyway I have mostly Fibaro motion sensors and battery last for more than 1 year even in rooms where is lot of movement. Also have Aeon MS6 powered by USB. Indeed older version 2.8 of Fibaro eye can get stuck even that was in my case very rear while new GEN5 (v3.2) are much better and reliable.
Battery life is depended on many things but mostly how parameters are setup and wakeup interval. I have learned that default settings are not the best.
Yes, I know that settings can have significant impact on battery life. But I don't know why, my Fibaro sensors are behaving strange for past few months. Very often remain breached for significant time (e.g. 7 hours), they are not reporting battery status correctly, and battery last max 3 months. I checked all parameters and setting are quite conservative in terms of wake up times, reporting intervals etc.
BTW - that Chinese sensors should be all the same but different branding. I'm going to test these now:
