[Solved] API addEnergyExtension usage
Message added by T.Konopka
what is this? can be used on a VD so to get on Energy Panel???
/monthly_2018_09/image.png.e181af6d04d668214dc06f76f5565b21.png" />
Edited by korniza
4 answers to this question
15 hours ago, korniza said:
what is this?
one ca add energy measurement feature to device, like on UI the the box for Fibaro Double Relais, where you can add the assumed consumption when device is on. If the device support measurement and you call "addEnergyExtension", it will do the rest foryou, if the device does not support measurement, you have to add value via interface - this is so far i remember
no
2 hours ago, korniza said:
example about that?
data = '{"deviceID":1234,"action":"addEnergyExtension"}'
post blah blah data :) my laptop is off
    @T.Konopka can you provide any info/example about that?
    @tinman thank you! Hope some day fibaro add custom energy measurements to Energy Panel.
    or just custom panel for any kind of sensor
