Push values to Domoticz
Hello
I am pushing some values from Fibaro HC2 to Domoticz.
I want to include more devices in the script below. How will the code look like if I want to update 10 devices instead of one in the same script?
Greatful for your help
And i do not need the debug step either
%% properties
%% globals
local WashWatt = fibaro:getValue(53, "power")
local http = net.HTTPClient()
  http:request('http://192.168.10.202:8080/json.htm?type=command&param=udevice&idx=76&nvalue=0&svalue='..WashWatt, {
      success = function(resp)
        if resp.status == 200 then
          fibaro:debug(resp.status)
        else
IMHO push model for this not OK.
can you develop pop model from Domoticz? for example,
call every 1-sec
to get information about what happened in HC2?
Edited by 10der
