Change IPAddress from VD
Hi, I would like to do the opposite of what the command is doing:
with a button of a VD I would like to change the ip of the VD, is it possible?
thank you
change_ip = api.put("/virtualDevices/"..device_id, {properties={ip="1.1.0.0"}})
or
local new_ip='1.1.1.1'
change_ip = api.put("/virtualDevices/"..device_id, {properties={ip=new_ip}})
-- checking change of IP
fibaro:debug("new name: "..change_ip.properties.ip)
