xirilius 0
I'm lost.... can i use linked devices (or something else) to combine Heating Panel (HP) with Heat-it Thermostats (HT)?
I want to use the time and temp settings in HP and send them to my thermostats.
Can HC2 do this for me or do i have to write a LUA scene,
i know how to write that scene, so that is not the problem.
I need to know if this is a standard HC2 option or not.
Example:
at 7:00 HP-1 sends 20 degrees to HT-1 in the livingroom, HT-1 shows the temperature in the display and controls the heating
at 09:00 HP-1 sends 15 degrees to HT-1 in the livingroom, HT-1 now shows the low 15 temperature.
at 8:00 HP-2 sends 20 degrees to HT-2 in the office, HT-2 shows the temperature in the display and controls the heating
at 17:00 HP-2 sends 15 degrees to HT-2 in the livingroom
and so on with the other thermostats and Heating Panels.
Edited by xirilius11 answers to this question
