hello how do I get a motion sensor that when triggered, does it turn on an on / on lamp? Then let it light for 10 minutes.
Then again, trigger the lamp again before the time expires. all should be written in lua codes.
  04 Sep 18
Modified Fibaro code, work with fibaro and neo multi-sensor, but you have many other simplest solution at this forum (section Crowd's Solutions)
