CWestermark 0
I am trying to get the sceneActivation value back to 0 after a dimmer press. The below code gives 14 upon a double click on the dimmer. However, next time it reads local "sa = tonumber(fibaro:getValue(33, "sceneActivation"))" it gets 14 again. I would like it to get number 14 only upon the event of a double click on the dimmer. Can I achieve this by setting some parameter in the dimmer setting?
Basically I want to create a scene that triggers every time I press a dimmer. But not in between.
%% properties
%% events
%% weather
%% globals
0 sceneActivation
Time
local sa = tonumber(fibaro:getValue(33, "sceneActivation"))
fibaro:debug(sa)
if (sa == 14) then
fibaro:debug('2clickon')
sa= 0
