Roller Shutter 2 limit switch
I have connected Roller Shutter 2 (version 25.25) to homee. Unfortunately I am not able to calibrate it or to properly operate it via manual switches as I can't convince the device to recognize the limit switch.
I have tried all variants for parameter 18 from low to high values but it doesn't recognize when the motor has reached the end position. So it simply moves according to parameter 17.
Any idea how to approach that? I am using momentary switches (up/down where only one can be switched at the same time).
