Hello
I have a widom energy driven switch module (current tr) that I use to measure the consumption of my system, I would like the HC2 web page on the top left to show the value of this module and not the sum with other modules that measure the single user , is there an alternative to disabling the "Show energy consumption measurement" item in each individual user?
Answer is no and yes :-). No there is not such a option with HC2. Yes, there is a workaround, but you need to have either unused relay or other device with power metering to which you you will assign calculated negative power of sum of all devices beside widom, or just simply disbale power meter reporting of all other devices beside widom (but you will lose this interesting info on device level). Try to find the topic solving "total home consumption display" where all relevant info is.
