3JL 7
For some weird reason, my HC2 just got unreachable via web browser... I restarted using the device's power button, no effect. Then I used Fibaro finder which found it but it now has an IP address outside the normal range.
My router uses a static routing map to fix the ip. Other IPs are normal.
Any clue whether this is a router problem or an HC2 problem? What would be the recommended way to recover?
(I tried removing the HC2 from the static map - with no effect)
Edited by 3JL2 answers to this question
