Heat-it overrule measured power?
Hello, the new V2.6 Heat-it thermostats can measure the power usage and that is great,
but is it also possible to overrule the measured power by setting a 'declared power consumption'?
I connected 'a big 3-fase Crydom solid-state relay' on the heat-it output (8 Kw electric heating is a little too much for the Heat-it),
so the Home Center consumption graph shows only 0.2 watt (relay power usage)
